RCU Forums - View Single Post - what do i do
Thread: what do i do
Old 01-17-2007 | 03:08 PM
bluecaka69's Avatar
bluecaka69
Default RE: what do i do
Pics up know and just a little hint there in a mod that you can do
This first mod is very simple and easy. What you do is cut the tip of your stock header off using a cutting wheel. Not to much only about 3/8ths of an inch.
What this does is helps reduce the chance of your revo header being bent. This was first done by a few members over on traxxas forums. Another benefit you will receive is the increased performance on the low end performance of your motor.
Below you will see a stock header on the left and a cut header on the right.
