RE: Where did I go wrong?
r2Champion, it is impossible to reverse the direction of throw on any modern servo by changing the leads outside the servo itself. If you think you succeeded by doing so, your memory is failing you. If you have restored the leads to their original order and the servo does not work, you have destroyed one or more components insided the servo.
