RCU Forums - View Single Post - Direct Injected UAV Diesel Engine
Old 01-17-2007 | 07:52 PM
ama1836
Default RE: Direct Injected UAV Diesel Engine
This is a compression ignition diesel. here are some of the specs for the engine.
Weight 3.8 Kg
HP 3.5 HP
RPM range 3500 RPM Min / 5100RPM Max.
Prop specifications 27-10
Max RPM 5000 Max.
This engine is being evaluated in Tazmania with results to follow.
Steve
