RCU Forums - View Single Post - Matt Chapman cap 580 .40 size
Old 01-17-2007 | 08:27 PM
  #1155
e28m5
Default RE: Matt Chapman cap 580 .40 size
The spacer slides onto the axle, then the wheel, then the collar. So the axle thread goes through the gear hole, and the nut is screwed on from behind. Then slide spacer over axle followed by wheel. My pants have a large semi-circular hole on the gear side so they can clear the axle/spacer assembly. Hope that helps.
