RCU Forums - View Single Post - phoenix decathlon
Old 01-17-2007 | 09:54 PM
  #49
RCVFR
My Feedback: (7)
Default RE: phoenix decathlon
ORIGINAL: T28RON
I have a Bellanca Decathlon with a WS of 106". wing area is 1583.5". No plans. Havent got the total weight because am trying to figure out what engine to put in it. Needs fuel tank and batteries. This plane was a Bob Hollman plan and built by Don belford who is supposed to be an article writer for Flying Models. I have tried to make contact with both Don B. and Bob H. but no responce. Does anyone have any suggestions as to what would be the proper size engine for this? Tks
Ron
I built the Dynaflite Decathlon, at 89" WS, 16.5 lbs, powered with a G38, 18X8 prop. This is a good flying combination. I was limited to an 18" prop due to the length of the landing gear. You will probably want at least a 20" prop. I would guess a G38 would be at the lower end of power for your plane, depending on the all up weight. This might give you an idea as a starting point.
Good luck with your Decath.
