Ok, just getting back to this problem.. now that nicer weather is here..
Did as you suggested but still having problems.
Checking everything I can, but I may have found the problem.
On the bottom of the carb barrel opening there are 2 holes. I'm making the assumption that when the carb barrel rotates to idle that the fuel is directed thru this port. I'm hoping that you will tell me that this should vent to the hole just below the barrel on the side below the intake tube. You can view these 2 holes really well from the high speed needle valve side.
If this is correct then I'm thinking I may have a bad carb body as I cannot get anything thru these openings, spray cleaner etc. I have tried really fine wire to make sure it is clear but nothing wants to go thru..
Waiting for you reply
