I can't remember if I did this on a MOKI or an ST, but if the front of the crankcase, the bit with the carb on it, is bolt-on, then you can rotate it 90 degrees and run the engine backwards???
Even if I am wrong it is an easy/harmless-to-the-engine test to try!!!
Which direction of rotation do you plan to run the left and right engines? I ran mine with the top of the prop going towards the fuselage, looking from the front. This worked best in case and when one engine flamed-out.
Regards,
Eric.
ORIGINAL: hanna
Does anyone know where I can get a reverse rotation crank for a Moki 2.10. I am building a Yellow P-38. Any opinions? Thanks, Mike Krizan
