RCU Forums - View Single Post - blade clack?
Thread: blade clack?
Old 01-18-2007 | 01:53 PM
S.n.a.k.e.
Default RE: blade clack?
ORIGINAL: soloboss
Some will say you can't invert a CX/2.
Wrong.
Truth is that you can't FLY it inverted.
And upside down is expensive.
I would surmise that with some of the mods being discussed that you are correct. However, once inverted, no matter which way you moved the throttle, it will make the copter go down (very quickly in one direction, 32 fps the other). However if you could fly it out over a very deep hole, you may be able to right the copter after it was inverted.
Anyone (else) want to try this?? I'm curious...
Regards,
Marc
