RE: 1/8 hyper 7 schocks..?
Is it level when it comes up? By have way do you mean u can lift the car up without the tires coming off the ground at first? If so this is good. Its called uptravel and you will need some in the rough stuff. It should not shoot back up like a rocket. The diff oil slows the spring action.
