RCU Forums - View Single Post - right thrust...how do you know how much
Old 02-03-2003 | 07:21 PM
OUTCAST
Default right thrust...how do you know how much
Also note that the amount of right thrust will change with different diameter and pitch propellers, and sometimes with different make props even if they are the same size. Smaller diameter higher pitch usually requires less than larger diameter shorter pitch for any given engine.
Rein uses the correct method, and it does take time.
