RE: A leak in the engine....?
The line that connects the fuel tank to the exhaust isnt a fuel line, its a pressure line. if that has a leak the pressure is being let out so the engine does not have enough pressure to run. Your fuel line is fine being that the car is running, however if the leak gets worse the car wont run and you cant get it started until you replace that line. Try to notice if anything else aroung the engine is wet.
