RE: Radio problem
You imply that it works OK when you are less than 10 feet away. This is quite weird because even a poorly tuned radio will generally work up to 30 or 50 feet away with the antenna collapsed. Remove and replace the crystals in both the transmitter and receiver. And check the transmitter battery voltage under load. Does the transmitter have a voltage display on it?
