RE: Pitts s2b by Cermark
Hey Waynem,
Wheel pants on no pull-pull.
I used HD 4-40 and Giant scale racing servos w/ HD dubro connectors. No slop!!!
I would bring plane in at 1/4 throtle until you are about 6' off the ground and keep holding the elev more and more til you run out(have a high rate on if needed for landing) and you should then be a foot off ground and it will land nicely otherwise you will have bounces to deal with. With the lightened G26 I used I had to add an onuce or two at the rear, which was ok cause I planned to put smoke on it eventually anyway. Let me know how it goes
