RCU Forums - View Single Post - Brushless - Battery Life and DD tail CPP
Old 01-20-2007 | 09:23 AM
orlbuzz's Avatar
orlbuzz
Default RE: Brushless - Battery Life and DD tail CPP
MattMaynard,
Yep, I use the stock t. motor mount. You just have to Dremmel out the front of the hole for the motor to make it round to accept the GWS motor, and then it "bolts" right in using the stock holes and the GWS screws (the stock screws are too small).
I set it up like Nick Maxwells: http://www.rcgroups.com/forums/showthread.php?t=580952 and: http://www.rcgroups.com/forums/attac...mentid=1018871
The motor is GWS ED"P"50H also known as GWS CN12-RXC (both numbers are on the package) I couldn't find an "F" motor, I think they are the same, actually.
I used a larger lipo when I was leaning to hover, but I find I like the response of the smaller lipo, and I don't want to overheat the motors by flying too long. Besides, 5 or 6 minutes is enough for my skills at one time.
Hope this helps, there's been a lot of discussion on this, search around.
orlbuzz
