RE: Cross hatching
Most of the motors you convert will be one piece cylinders with the "head" integrated. There is just a base gasket for the cylinder and a gasket between the crank case halves. Only other gaskets in a typical engine are the one s between the intake block and the cylinder and the carb and the intake block.
