RCU Forums - View Single Post - Eletronic engine syncronizer **SUPPORT **
Old 01-20-2007 | 11:52 AM
  #191
yl5295
Default RE: Eletronic engine syncronizer **SUPPORT **
You can order them from RC Showcase or from me direct. Their web site is http://www.rcshowcase.com or you can email me at [email protected] Please do not send me RCU PMs since I often do not have computer access and I can respond to emails from my PDA.
The Twinsync is programmed for GAS engines as the factory default. The only difference in GAS and glow is the timing/engine response time curves. Using the factory default timing settings work fine on gas or glow. However, if you speed it up a little when used with glow engines it reduces time to sync from about a second to about 1/4-1/2 a second.
