RE: Sukhoi 26/29 plans
I built the MAN 29 by Sirianni. Only real problem with the plans was the two wing sections that you cut and tape together didn't match correctly, I just redrew them A little. I did make some changes because I used A Brision 40cc gas engine so I beefed up the front half of the fuse and made the cowl top so it would come off for engine installation. It was A fun build. Servos are HT6985s all the way through except for the throttle, no choke servo needed. Flys better then any other 80 inch plane I have flown, way lot of power. I would build another one. Came in at 15 pounds but would have hit the weight advertised without my mods and engine I used.
