Yes, BP hobbies is good. They are usually cheapest. Why do you think you need the bearings? The 263 goes in the little plastic bearing on the inner shaft.
that thing. It goes inside of that. The 483 bearing goes above the inner gear, look in the shaft hole from underneath the chopper, there should be a shiny bearing in there, that's the 483
