RCU Forums - View Single Post - Aspect Ratio ??
Thread: Aspect Ratio ??
Old 02-03-2003 | 06:26 PM
JimTrainor
Default Aspect Ratio ??
Since the chord may vary, you'll also see the aspect ratio
defined as the span divided by the square root of the wing area.
Martin Simons' book:
http://www.amazon.com/exec/obidos/AS...285061-3940604
... discusses the subject.
My potentially inaccurate (standard disclaimer ) recollection is:
High aspect ratio wings are more efficient than low aspect ratio. Tip vortices have a lot to do with this. As the air swirls around and near the tip of the wing it reduces the effectiveness of the the wing area near the tip. A high aspect ratio wing has less area, relatively, near the tip than a low aspect ratio, hence higher efficiency.
The cost is a more acute (steeper) lift versus angle of attack curve. This translates into greater pitch sensitivity and more severe stall characteristics.
