RCU Forums - View Single Post - Outrunner Problems
Old 01-21-2007 | 07:40 PM
saucerguy
Banned
Default RE: Outrunner Problems
I got it working, I bent the area where the wires attached to the motor, didn't even have to take it apart and found out it was indeed shorting out, after I found the sweet spot where it was supposed to be at, I hit it with some hot glue to help insulate that area and keep them in their proper area, now as long as I don't overheat the motor, it should work, it's now powering up correctly, definetly not going with the same mfg. again, they should have engineered a little more clearance for those, the thing is ultra light already, some extra area wouldn't have affected performance at all, then again, I never had a problem with the nimh's weight wise compared to lipo's as well, but I don't fly 3d.
