ORIGINAL: abel_pranger
ORIGINAL: Mode One
Separate what's said here on the R/CU AMA topic, from the realities of the AMA. 160,000 plus members vs. 8-10 people voicing opinions good or bad about the AMA. I can't say all 160,000 member are happy about their membership, they just don't see fit to voice what they feel's wrong, here. I would hope someone whom has an actual issue with the AMA takes it up with someone from the AMA that can address the problem.
Above all, remember the age old adage: Believe half of what you see and nothing you hear(read).
Inasmuch as you posted that here on the RCU AMA topic, why should anyone believe you, if one were to suppose that what you said might be true? [
AB-SOOOOOOOLUTLY, only believe half of what you see ME do, here on R/CU, and nothing that Mr. Pranger says! Then, you'll be in good stead, Flannelmouth. [sm=thumbs_up.gif]
