RE: OS 46 LA inverted problem
I own an fl 70 4c, the one with the airbleed carb. Ran horible inverted, as you described. Mounted sideways, problem partially solved. Low end always acts rich but i was able to at least keep it from quiting when pointing the nose down at idle.
