RCU Forums - View Single Post - OS 46 LA inverted problem
Old 01-22-2007 | 08:38 AM
ryanofoz
Default RE: OS 46 LA inverted problem
So there are known problems with the 46LA running inverted.
When you say drill it out, are you putting the same screw back in? As you said in yor post, I have backed the screw out as far as I can and it still acts the same.. To me it seems that the engine just does not like being inverted. However, as others have said, I have not put enough time on it either. I typically use the FX engines and have good luck with them. I just didnt want to try and shove a 46ABL in the front of the plane. Seemed a bit much. The LA engines I have ran upright have been just fine and very reliable. This inverted one seems to be a real pain.
Ryan
