RCU Forums - View Single Post - axe cp thread
Old 01-22-2007 | 10:32 AM
  #93
chaseman81's Avatar
chaseman81
Default RE: axe cp thread
What tail rotor blades did you get? Axe cp or Blade CP? I hear the blade CP blades work just fine.
Thanks, about the hovering practice practice. I use the duramax ICE I don't have a balancer yet. But My buddy that has a bunch of them (he works at the hobby shop) says I won't need a balancer for a month. But when I have 4 Lipos I should get one to make things last longer. I WILL HAVE ONE BY MY NEXT PAYCHECK!
As far as hovering watch for the smallest movement and try to counter it before it happens...
Get the heli about 3 feet off the ground too. I stops the ground effects. Some cool guy's from the forum told me that and it helped allot. The heli doesn't move as much. I am getting two 9-10 minute flights off each charge. That also helps because you gettime to get more comfortable before you have to wait an hour to fly again commpared to 5 minutes withthe battery that comes with the Axe.
Chaseman
