RCU Forums - View Single Post - How to build from plans?
Old 01-22-2007 | 05:44 PM
bruce88123
Default RE: How to build from plans?
ORIGINAL: Quinoa
What kind of material do you use as building bord, to be able to insert pins,...?
Is it important to use T pins? Which is the aim of using T pins? Where should they be inserted? in the building board?
What kind of tools are also needed (pins, pincers,...) and for what (fuselage, wings,...)
Thank“s for the inputs again!
Board? ceiling tile. 2ft x 4ft in size as used in interior ceilings Cost @ $3-5 each
Pins? varied use. Can be used to "trap" part and hold it down or it can pierce part to hold it. Thin pin is best for minimum damage if penetrating parts. T-pins easier on fingers and easier to remove than other types of pins.
Tools? single edge razor blades (buy in bulk to save money, hobby knife with #11 blades (spare blades too), long (needle)nose pliers, small clamps(clothes pins with springs in them often will do the job), small phillips and straight blade screw drivers, various sanding blocks with assorted grades of paper(non-cloggong type), covering iron minimum and heat gun very handy.
