RE: Senior Telemaster Mods
I've built several of these. I usually sheeted the fuse with 1/16 inch sheet balsa which did not add much weight and definetely eliminated the twisting under load. I also removed all the dihedral from the wing, made them bolt on and increased the rudder size by at least 50%. No matter how you build yours, I'm sure you will find it a pleasure to fly.
