FP,
I agree with what you said.
But as you stated
"Geistware, I get several recommendations to use both types. Each person has their own reasons that prove their point.
In my long experience every time I receive many divergent views with proof it usually means that either case will work. Each method has it's merits and detractions. The real key for any solution is to be aware of the good and bad points of both cases.'
The point I am making is that, what I stated was fact. Others may tell you different. If there is any doubt, don't beleive what I or anyone else tells you, test it for yourself. If you don't have the equipment, then pick someone to beleive until you learn or see different.
ORIGINAL: fastplane
Bill, you are confused. If you read my last post I understand the words but as I said I don't have the equipment to do what is being well thought out answers. What good is an answer if I don't have the equipment and don't understand the technical details.
I think this thread has gone on long enough. Let's let it die because of lack of interest.
