RCU Forums - View Single Post - Using nitro
Thread: Using nitro
Old 01-23-2007 | 03:43 PM
DarZeelon's Avatar
DarZeelon
Default RE: Using nitro
Bill,
According to the MVVS head engineer, the engines can all be run as they come, on up to 5% nitro.
If you need to use up to 15%, add one head shim (a total of 2) and off you go.
The RPM gain from going to 15% with the extra shim is 100-200 RPM.
Make sure you use only fuels that contain plenty of castor oil (over 50%).
...Unless it is Cooper's and then you can use less.
