RCU Forums - View Single Post - BRIO ENGINE OFFSET
Old 01-23-2007 | 09:39 PM
MTK
Default RE: BRIO ENGINE OFFSET
Frank, let's talk. I've designed and built a simple device that you can use directly to measure engine offset. It requires that your wing is level but that shouldn't be too difficult to get.
Matt
ORIGINAL: F.Imbriaco
Hi Don,
Do you have knowledge of the engine degrees of offset ; right and down Thrust on the Brio ? Haven't been able to find it in print or in your Brio by the numbers.
