RCU Forums - View Single Post - servo dancing at switch on
Old 01-23-2007 | 11:40 PM
flybyme's Avatar
flybyme
Default servo dancing at switch on
]I've just finished assembly of a GP Stilk .40 ARF and when I switch it on, the servos start dancing all over the place........I assembled it according to the instructions with the rx and bat up front of the servo tray.......the antenna is poked outside mid fuse thru a small hole and routed along side to the trailing edge and up to the tip of the vertical stab........does it need to be in a plastic tube? I've seen that setup before.......I took it thru the side of the fuse to the outside so it would not have to pass over the servo tray/pushrods and the four landing gear support bracket "blindnuts" on the fuse floor.....also included and installed is a 24" Y-harness for the wing servos...this seems to be a lot of wire in a small space on top of the rx and bat........would it do any good to shorten the harness or is that even a option?
flying is like breathing, everybody should do it......
