need some help on starting...
1 Thing about the Wingo/Soarstar/Poppy planes. Anything other than a perfect wheel landing will damage the front of the plane. Any little nose first landing will crack the cockpit. Nothing a little epoxy can't fix but it gets real ugly real quick. Also if your nose in first landing is a little harder, you'll brake the neck of the plane. (the long part of the fuse that holds the wing.
Good Luck.
