RCU Forums - View Single Post - How to build from plans?
Old 01-24-2007 | 03:23 PM
Charlie P.'s Avatar
Charlie P.
Default RE: How to build from plans?
. . . by using T pins am I damaging the balsa?
Yes, but not enough to effect it in any structural way (unless you REALLY stick in a lot of pins. I do not stick pins in the spars. They're harder wood and there is a danger of splitting. That's when I use the rubber band between two pins trick. You should be careful when sticking into the edge of balsa - like sheeting over ribs - that you don't split the balsa. Titebond II or other white or yellow glues fill the little cracks if they do split.
It will also make your iron-on covering stick better initially and without developing air bubbles later on. It's true! The little holes allow the trapped air to escape.
