ORIGINAL: Quinoa
Hi everybody,
Can someone explain to me how should I beginn to build a plane from a plan?
Should I stick with scotch tape first the plan onto a wood surface? Should I protect the plans to prevent damages?
Which material is the best to protect them?
Is it important to use T pins? Which is the aim of using T pins? Where should they be inserted? in the building board?
What kind of tools are also needed (pins, pincers,...) and for what (fuselage, wings,...)
I thank any help from you.
I just want to know the best conditions, the best way, to beginn building
I realize that these questions can sound easy to answer. Not for me!!! I promise
Alberto
I would suggest that you check out
http://airfieldmodels.com for information about building.
