RCU Forums - View Single Post - How to build from plans?
Old 01-24-2007 | 06:27 PM
  #33
skylarkmk1's Avatar
skylarkmk1
Default RE: How to build from plans?
"Yes, if you used wax paper and give each pins a 90ยบ twist before pulling. "
And the wax paper/plastic film will normally peel right off the part you are building. Use enough glue (epoxy and Tite-Bond type), but use it sparingly and wipe up any excess (don't try to wipe up CA . It will reduce weight and look better also.
