RE: 140 Crankshaft question
The hole is for crankcase pressure to drive the regulator, but the early FZ used the lower left fitting on the backplate to drive the reg the other way. Put it in and try it, if it doesn't run, you won't hurt anything, so go for it and see what happens.
