RE: Bypass material
Hi there Harry,
I have made bypass's out of carbon cloth and while wet a layer of wing skinning cloth, which makes it strong and the outer very smooth. Do people use carbon because it is more rigid once set? As far as blade retainment goes you could use a carbon/kevlar mix but kevlar impregnated with resin is not very resistant to being cut than carbon is so there may be little advantage.
Jason
