Equus, Start with 1/2 turns and continue from there
ORIGINAL: equus
thanks ...
commander bob i say everything fine is fine because i think i don`t know how to check the correct level
mykul812 : the only chrash was when my heli fall off the table i made a mistake and tried to check the controls and didn`t disconect the motors the blades hit my hand and then fall off the table a blade was broken, but however before this i noticed the problem was there, i `ll try to adjust the linkages as you and comander bob say ...
is there any measure ? if so can you tell what is the correct and i can check it with my vernier (caliper)..
Thanks guys
