RCU Forums - View Single Post - Super Tiger vs Moki
Old 03-10-2003 | 04:47 AM
  #34
Flyfalcons's Avatar
Flyfalcons
Default Super Tiger vs Moki
Don't know about thrust, but if you're five turns out and have to adjust the throttle to go lower than 7000 then you aren't getting it rich enough. With a Perry pump mine is 1-1/2 turns out for flight, and turned a Top Flite 18x8 at 8800 RPM. Since then I installed a Zinger 18x6-10 which performs better. You should be able to get the thing to die by turning it out 5 turns. 9000 might be possible on certain props.
