RE: Nosen P-47 Build Marathon
Here you can see the beginning of the pull pull system for the tailwheel. There will be springs in the lines at the servo horn to take up the slack when the wheel is retracted. There are also some pics of progress on the engine mount box. The gas tank will go inside the box and the air tank will go on top of it. Sometime in the near future, I will start installing the servos in the fuse. There are pics of the start on a servo tray plate. It will eventually be glued in to 1/2" tri stock glued to the sudes of the wing saddles and formers.
