RCU Forums - View Single Post - Brushless tail setup?
Old 01-25-2007 | 10:52 PM
MattMaynard
Default Brushless tail setup?
Heya, quick question on wiring. I have a brushless main and esc. Also a HH gyro. Got a 2nd ESC and brusless for the tail. The HH plugs into the RX on rudder. The ESC 3 control wire plugs into the Gyro. Do I need to disable the red middle power wire? When I do unlplug it, the Gyro gets no power (not powered through the rx connection I guess.
My questions are...
Do I need the mixer anymore or can I just use the RX?
Do I need to disable the pin from the 2nd tail esc? If so, where would the HH get power?
If I remove the mixer 3-in-1... how will the RX be getting powered? Should I re-enable the red power connector on my main motor's esc to power the RX since it's not connected to the battery anymore?
Basically just need a wiring diagram or what-not so I don't end up frying something. =P
Matt
