Justin,
Also the switch is in the anolog (I had it in digital at first and it totaly fliped out). It holds fine but it acts like the gain is set too high, but it's not. It just wags. It even wags when the gyro is not attached.
Well then it would seem since the tail wags without the gyro that it(nor any setting for it are the problem.
The problem must be with the tail motor or esc. Its cheeper to try a new tail motor, but if you know anyone with a bcpp I would try to see if you can install their 3in1 for a test flight.
Possibly for some reason the gain on the 3in1 gyro is set too high and does not turn down when you turn down the pot dial on the unit? Unfortunatley you may have to spend some $ money to complete the process of elemination.
Gl,
noah
