RCU Forums - View Single Post - CA Question
Thread: CA Question
Old 01-26-2007 | 07:22 AM
rwright142's Avatar
rwright142
Default RE: CA Question
WARNING!!! CA IS HAZARDOUS TO YOU HEALTH!
OK, now that I got that out... I learned this the hard way. Before I joined RCU, I used CA exclusively. For some reason I thought I had to. One day after working on my TopFlite Corsair, I had pains when breathing. It was like my lungs were on fire. I did not put 2 and 2 together until the next day. By conincidence, I joined RCU the next day and read about others and their experiences with CA. You will get many opinions, but I only use CA when absolutely necessary, which is very rare. For critical areas like wing joiners, I use 30 min epoxy. For everything else I use the alphataic glue that DavidAgar mentioned. That is the yellow wood glue. I use TiteBond and so far has worked great.
If you do use CA, make sure you were a mask and/or ventilate.
Good luck!
