RCU Forums - View Single Post - TESTED DIESEL FUELS - completed
Old 01-27-2007 | 09:11 AM
merugo
Default RE: TESTED DIESEL FUELS
MIX NUMBER: .05................................. SUGGESTED NAME: Normand mix .......,DATE: 1/25/07...........
ORIGINAL REPORTER: JMP_blackfoot ...........LAST EDITOR:merugo.............LAST EDIT:1/27/07......
OTHER USERS:
FORMULA (in order of decreasing percentage of volume ):
1)-40%.kerosene......................
2)-.30%ether...............................
3)-28%castor oil...........................
4)-2%ICI AVOCET ignition improver.......
5)............%................................... .......
The way the mix it was obtained: straight.......................................... .................................................. ......
1)ENGINE:WEBRA WINNER 2.5cc CARBURETOR: .... .. RUN TIME: ...........STARTING: ....................USER:JMP_blackfoot.
Comments:starts and works well at low temperatures (0°C)....................................
2)ENGINE:.............CARBURETOR:.........RUN TIME: ...........STARTING:........................ .. USER:...................
Comments:......................................... ..................
Additional user observations:
Nickname :........................ Observation:
Non user comments:
Nickname : merugo......Comment:.Avicet is a mix of nitric esters apparently formulated for alchool diesel fuels, to be used with them from 5 % up to 8%
Nickname :................. Comment:.......................................... .................................................. .....
PURPOSE:
SHARE FORMULAS, EXPERIENCES AND SUGGESTIONS.
RULES:
EVERYONE CAN ADD HIS EXPERIENCE AND/OR BRIEF COMMENT FOR A GIVEN FORMULA by reediting and setting edition date
USE:
COPY; EDIT AND PUBLISH. NO CONTRIBUTION CAN BE MODIFIED IF NOT BY ITS AUTHOR
END
