First Kit. Need Help with Supplies!
MockV
A few more items that are important:
Needle nose pliers (miniature)
Combination square - how else will you get the formers straight?
Titebond - wood glue
Small spring clamps - clothes pins work fine also
Sanding block
Razor plane
Metal yard stick for a straight edge - take the ruler out of the combination square for short surfaces.
Band-Aids for the small cuts from the xacto knives - tourniquet (yeh, that's the right spelling, I looked it up) for the big cuts.
5 minute epoxy for the small/quick bonds that need strength
A nice assortment of drill bits (small)
And above all a flat building surface!!!!!
