RCU Forums - View Single Post - Minimum gap around turbine in bypass.
Old 01-27-2007 | 01:09 PM
I-NAV's Avatar
I-NAV
Default RE: Minimum gap around turbine in bypass.
3 or 4mm isn't much. I have a tight installation like this on my F-106. I'd run it on the ground and see if the pipe runs hot. In flight, the air is going to stack up in front of the bypass. You might need to cut a few vents in the front to dump excess air around the outside which wouldn't hurt cooling.
