RCU Forums - View Single Post - Jack Stafford Chipmunk
Old 01-27-2007 | 01:22 PM
  #45
WacoNut's Avatar
WacoNut
Default RE: Jack Stafford Chipmunk
I have the wing saddle roughed in and the bottom sheeting glued on. I am using Elmer's Wood Glue to glue the sheeting on because I will be sanding into the joint when I contour the fuse to shape and the Elmer's sands much easier and wil leave a smooth surface. Once the glue is dry I will shape the bottom of the fuse then finish up the wing saddle and mount the wing.
I will work on hingeing the flying surfaces while I wait on the fuse to dry.
Anthony
ID:	607655   Click image for larger version
ID:	607656   Click image for larger version
