RE: Falcon 3D - Glitches Help Thread.
I've never had any glitching problems with mine personally, but have seen reports from several others about glitching.
Off the top of my head, here are some things to check:
1. Make sure the antennae in your TX is screwed in snugly
2. Make sure the crystals in both the TX and RX are seated fully
3. Make sure the ESC is not too close to the RX. Definitely not right below it. Mount the ESC as far to the rear (motor direction) as possible.
4. Make sure the batteries in the TX are good, and seated firmly. squeeze and gently shake the TX while observing the LED on the front. If it flickers or turns red, etc, then you have a bad connection somewhere (This happened to me with another heli once)
That's all I can think of right off hand. I'm sure I've left some stuff out, but I'm sure others will contribute also...
