RE: Does my Ryobi Have the Power?
Fireman,
If you use a stock 7mm carb, your rpm will be lower with a oversize prop. Also you can bend the reed stop plate out some to get more intake flow. Be careful that it is clear of the crankpin and rod. If the engine is new, it will get better as you run it in.
Dave
