Got my HPI Shock shafts:
http://www2.towerhobbies.com/cgi-bin...?&I=LXN177&P=0
They fit almost perfectly on the Tornado's shocks! The only thing is the thread at the bottom is a mm longer meaning the shaft wont screw all the way into the bottom cup (no big deal) You can shave the mm off if you want but you don't need to. They also fit perfectly in the body hole. Stock up on these! They are made from steel so they will be alot stronger!! They are dirt cheap too. Also get these:
http://www2.towerhobbies.com/cgi-bin...?&I=LXM822&P=M if you don't have enough e clips, they work perfectly too. Ill take some pics of the shocks with those HPI shock shafts soon. Ill be putting a video up too of my buggy!
Does anybody have a Tornado body that is pre cut? I am so bad at cutting bodies.
