RE: Top Flite 1/7 P-51 Build
I am at the point to start covering the wings. Thinking about doing this by gluing the sheets together and applying this as one sheet. What type of glue are most of you using? Think that using CA would result in a very rushed job. Was thinking of using Titebond on the ribs, spars and trailing edges and CA the leading edge. Then would stack magazines on top of the sheet to hold tight to ribs etc until dry. Think support on the spar and leading/trailing edges may be required to support the weight of the magazines.
Suggestions?
Bruce
